The problem with Share variable in LabVIEW8.5
I created a network share variable in LabVIEW 8.5.
But after I changed its properity to "Target relative",I came across a error "Error 1003" when built an exe. And if I changed it to "Absloute",I got no error!
Is that a bug ? or something wrong I did?
(3,697 Views)
Hey,
I was able to reproduce this behaviour. Im not sure if it is a issue until yet, because the LabVIEW help says: " A target-relative Shared Variable node always connects to the shared variable on the target on which you run the VI that contains the Shared Variable node". So if there is no VI, but an executable maybe LabVIEW is not able to reference the node to the variable.
I will do some tests and post again!
Christian
(3,672 Views)
Hey Gadfly,
After a little bit of testing I would say.....it's a "small lifeform with mostly six or more legs", so I wrote a CAR, FYI CAR 4EN8GEQQ.
Christian
(3,661 Views)
Hi,Christian
I am sorry I cann't quite follow you.  What do you mean ?
six or more legs?  ?
Is this word "FYI CAR 4EN8GEQQ" an bug number ?
(3,626 Views)
Hi gadfly,
NI AE's (application Engineers) are taught not to use the word "bug".
Yes you understanding is correct.
CAR = Corrective Action Report
Ben
(3,618 Views)
Thank you Ben! Smiley Wink
(3,573 Views)
