Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
The problem with call library function node.
Dimon87
Member
03-25-2008
12:48 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi, I have the problem with call library function node. I loaded dll into the node and ran, then the error occured.
Thank You for answers!
My problem.doc 109 KB
Tags:
1097
call_library_function_node
error_1097
View All (3)
0
Kudos
Message
1
of 2
(2,890 Views)
Reply
Re: The problem with call library function node.
smercurio_fc
Knight of NI
03-25-2008
05:30 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
That error code can be caused by a variety of reasons, though the most likely is improper memory management. Without knowing what your DLL is doing, or what you're passing to it, it's impossible to say what the exact problem is.
0
Kudos
Message
2
of 2
(2,873 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
