The problem with call library function node.
Hi, I have the problem with call library function node. I loaded dll into the node and ran, then the error occured.
Thank You for answers!
(2,883 Views)
That error code can be caused by a variety of reasons, though the most likely is improper memory management. Without knowing what your DLL is doing, or what you're passing to it, it's impossible to say what the exact problem is.
(2,866 Views)
