The program doesn't find the run time engine
I create an executable before normaly and after like an installer. When I try it into computer with full LabView licence the program works, but if I install it into a different pc, it requires me to install the run time engine, but the run time engine is installed into the pc. What kind of error can generate this problem?
Message 1 of 8
(4,257 Views)
Hi vsara
Are you sure you have the correct version of the run time engine for your application? For example if you are using LV2009 development system you need the 2009 RTE. Could also be that the RTE installation went wrong. Have you tried reinstalling it? You can include the RTE in your installer. Do you use components from any other drivers (vision, DAQmx, etc) in your application?
Best Regards
David
NISW
Message 2 of 8
(4,255 Views)
I create the VI with 8.61version and install the LVRTE86STD.exe
Into the main VI I don't use DAQ, I use "VISA configure serial port" to acquire data from instruments, the "database connection" and "report generation toolkit" give some problem during executable creation.
Message 3 of 8
(4,246 Views)
Hi
Try upgrading the RTE to 8.6.1. Do you have NI-VISA installed on the computer?
Bes Regards
David
Message 4 of 8
(4,235 Views)
NI VISA is installed into the PC used to create the VI, but not the others pc
Message 5 of 8
(4,232 Views)
Accepted by vsara
Hi vsara,
if you use the VISA funcions in your program, then you have to install the VISA Runtime Engine (NI VISA Runtime) on the other PC.
Mike
Message 6 of 8
(4,229 Views)
Hi vsara
Mike is correct, you need the VISA runtime to use VISA functions in an executable. If you don't want to install it as a standalone you can include it in your installer as an additional installer.
Best Regards
David
Message Edited by Davidek on 10-23-2009 04:18 AM
Message Edited by Davidek on 10-23-2009 04:19 AM
Message 7 of 8
(4,225 Views)
Thanks a lot. I try with your suggestions.
Have a good day and thanks again
Message 8 of 8
(4,220 Views)
