The "Simulation Models" of NI VeriStand
Will the "simulation models" of VeriStand are run in FPGA?
(1,077 Views)
Accepted by topic author jingfeng_dong
Generally no, the models will run where the VeriStand engine is running which is usually on some Linux RT controller.
If you have a Simulink model you are able to generate VHDL code using their HDL Coder and then run that on an FPGA. Then you can use the FPGA addon to pass inports/outports/parameters to the model running on FPGA.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YG1cCAG&l=en-US
(1,052 Views)
