Hi David,
First a question just so I’m not misunderstanding. With:
“When it launches it takes about 30 seconds to load then I get about 5 to 10 seconds to control my application before the tag engine automatically relaunches itself.”
Is my interpretation that you try to kill/exit the Tag Engine repeatedly, but it keeps coming back correct? Or does it launch itself, then shutdown itself in a neverending cycle of frustration?
Anyways, a couple more possible causes of the Tag Engine launching before any code executes come to mind.
1) Tools>DSC>Advanced>Startup VIs...
Anything there that you forgot about? Somehow I doubt this, but if not there's always ...
2) Are you using any front panel datasocket connections?
If yes: Are any of your connections intentionally or accidentally to items with a url like “blah://blah/National Instruments.OPCLabVIEW/itemname”?
Fading out. " ... J. Arthur Rank on gong."
