There are no inputs or outputs on the DAQ assistant to connect to
I am glad that repairing the driver worked for you!
What exactly do you mean when you say that it will crash when you configure a hardware DAQ?  Are you able to take measurements from your card or does the program throw errors?  Can you post a screenshot or code that shows the behavior you are seeing?
Jordan F
Message 11 of 12
(492 Views)
I fixed it.  It turned out to be a setting with the trigger.
Message 12 of 12
(490 Views)
