There is no option in Vision Assistant block to close classification session! (How to solve Error 1074396030 ?)
Accepted by LearningLV
What I mean is that the algorithm is now implemented in LabVIEW and your VI is not linked to Vision Assistant anymore. If you double click on it, it now brings up its diagram with the code using the Vision API, instead of invoking Vision Assistant where you can experiment with different Vision functions.
Message 11 of 11
(731 Views)
