ThermoVision Labview toolkit installation Error
I am using 32 bit Labview 2017 in my 64 bit machine and trying to install Thermo Vision Labview toolkit (THV_LVTOOL_3.3.10 2013-10-7) for accessing FLIR Thermal imaging camera for my project. Whenever I am running setup to install this toolkit, an errors prompts saying 32 bit lab view must be installed for moving further in this installation even though I have everything in place ( coming under the requirements for this software). Can anyone please help with this?
(3,086 Views)
Hey Akshay07
How did you install LabVIEW? My first guess is maybe the Thermo Vision toolkit only looks for LabVIEW installed in a certain place and if you installed it in an unconventionally way it might not be able to find it.
Austin Stanton
(3,048 Views)
Hey Austin
I think its installed at the right place even though I haven't installed it but people before have actually used tool kits for other driver components on the same machine and using same labview.
Its stored in C drive and since its a 64 bit computer with 32 bit Labview its right now installed under Program files X 86 folder. Rest all other toolkits are still working perfectly fine with the application ( on Labview ).
Do you have any vague idea where exactly it looks for?
(3,045 Views)
