 WhiteKnight
			WhiteKnight
			09-16-2008 03:19 PM
I have 3 K-type thermocouples attached to a USB-9211A device using the LabVIEW-provided CJC constant. I'm using it to measure the temperature of a hot water bath for a period of days and after about 6 hours LabVIEW didn't read from the thermocouples anymore and put up a 0.0 value on the indicators. What could the problem be?
 smercurio_fc
			smercurio_fc
			09-16-2008 03:51 PM
09-16-2008 04:31 PM
09-17-2008 04:55 PM
Hello WhiteKnight,
Thanks for your post!
I see that you are reading 0 for a temperature after hours of operation. I would tend to agree that there could be an error here since the reading is going to 0. When you call your DAQmx read how many samples are you reading at that moment in time? Are sampling at the fastest rate of 12 S/s? If you could perhaps post a screen shot of your code we might be able to see if something is amiss here. Let us know if you are still seeing the issue.
Cheers!
Corby_B
http://www.ni.com/support
