Thermocouple
No. You can use all 32 differential channels.
Spencer S.
Message 11 of 14
(823 Views)
Could you let me know how to use all 32 differential channels. Any references?
Message 12 of 14
(823 Views)
The key is to use the correct channel numbers. The KnowledgeBase stated the following:
"This means that the valid channel groupings are 0-7, 16-23, 32-39, etc."
Thus, your 32 differential channels will be 0-7, 16-23, 32-39, and 48-55.
Have a good day.
Spencer S.
Message 13 of 14
(823 Views)
Thanks. The problem solved.
Message 14 of 14
(823 Views)
