Thermotron TCP/IP interface
Has anyone converted the Thermotron drivers for Chamber control to VI's that will run in LabView ver 9 or 10? Specificaly I an attempting to interface with a Thermotron 3800 controller via TCP/IP.
Message 1 of 10
(11,932 Views)
Accepted by SMP_INDY
I recently posted something that might help you on another thread.  I didn't use the Thermotron drivers, rather I used VISA based on their recommendation here (example).
Jim
Message 2 of 10
(11,914 Views)
Thank you that got me thinking in the right direction. Although I did it it TCP/IP rather that serial.
Message 3 of 10
(11,884 Views)
I basically wrote a standalone application that can detects and replicates most of the basic functions on the thermotron touch panel. It is very simple by referring to the thermotron user manual and send the command thru tcp protocol vi library.
Take a look at the details of the complete project and snapshot below: (Vote for me if you think it's cool!)
https://decibel.ni.com/content/docs/DOC-18615
Message 4 of 10
(11,561 Views)
Are you done spamming these forums?
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/thermotron/m-p/2048534#M54337
http://forums.ni.com/t5/LabVIEW/thermotron/m-p/2048530#M668229
http://forums.ni.com/t5/LabVIEW/Thermotron-TCP-IP-interface/m-p/2048526#M668227
http://forums.ni.com/t5/LabVIEW/Controlling-Thermotron-Basic-steps/m-p/2048524#M668226
http://forums.ni.com/t5/LabVIEW/Problem-with-driver-for-Thermotron-8800-in-LabVIEW-8-0/m-p/2048512#M...
Message 5 of 10
(11,554 Views)
Apologize for the spam, I do tried with tcp/ip and it works with LV 10. Sharing attached student-level created subVIs for Thermotron 8200. Smiley Happy
Message 6 of 10
(11,534 Views)
Can anyone please convert Thermotron TCP/IP interface to lab view version 8.2.1.
Rulee
Message 7 of 10
(10,999 Views)
Why do you need reminding of the version conversion board? You've posted there before.
Message 8 of 10
(10,979 Views)
Sorry for that and I only recall of conversion on the TCP/IP.
Rulee
Message 9 of 10
(10,969 Views)
You still have not posted your request to the version conversion board.
Message 10 of 10
(10,957 Views)
