Thorlabs .Net Gain Setting
I am using a Thorlabs DCC3260M Monochrome Camera. I admit I am not great with .net . I am trying to figure out how to set the gain. I can get a property node to show a "gain" property. But it gives (or wants the input of) a reference. I am not finding the way to connect this to a front panel object. I included a screen shot of a portion of their "simple live.vi" which as it suggests is a simple quick start for acquisition. It does everything else like frame rate etc...
How do I get a front panel slider connected to the .net functions so i can set the gain?
(3,727 Views)
Accepted by Shredderofmass2
If it's like the UC480, you have to drop a couple more property nodes to get at the actual gain setting. Like this:
(3,706 Views)
Yes, this is exactly it. For posterity, do this after the camera is initialized, put the code he shows here into the live acquisition loop. Works great.
(3,699 Views)
Ok, I am lost again. I don't suppose you have a quick and dirty way to convert the image to an imaq image or an array so I can use it with the rest of our imaq code?
(3,682 Views)
It's been a while since I have worked with a Thorlabs camera, but I believe they display everything with LabVIEW picture controls. If that's what you're using, you can try this one to convert the picture into an array of data.
(3,679 Views)
