Thoughts on Stream-to-Disk Application and Memory Fragmentation
This is a sample program that will (quickly) fill up a disk with files, using the Set/Tell EOF function.  An examination of the files will show that (under XP), most consist of 1 contiguous chunk of disk space.  As the disk fills, scavenging of fragments will occur, and the fragmentation rate will go up.  This probably demonstrates how XP allocates disk space.
Bob Seegmiller
NG UMS Ryan Aeronautical Center
Message 21 of 21
(410 Views)
