Tic Tac Toe 4x4
Hello everyone
I have a tic tac toe 3x3 game,  I want to change it become 4x4, but I'm still confused because I'm Labview beginner. I hope someone can help me, Thanks.
Message 1 of 9
(4,038 Views)
Accepted by michaelkeane24
Maybe this can give you some ideas....
Message 2 of 9
(4,020 Views)
Thank you for your answer Sir, but can you have more simple tic tac toe 4x4?
Message 3 of 9
(4,015 Views)
Hi Michael,
compared to your own TicTacToe code version Christians sources look far more easy to understand!
(Your code is full of misunderstanding of DATAFLOW and shows a lot of bad coding habits.)
Message 4 of 9
(4,008 Views)
You are making many glaring beginner mistakes:
  • Potential race conditions due to local variable overuse. (most will iron themselves out across iterations, but they are still not great!)
  • Learn about shift registers to retain data across iterations.
  • Having a constant wired to the toplevel conditional terminal, then an abort Vi inside a useless sequence structure inside a case structure is just insane. Where did you learn that? Just wire the button to the termination condition, stopping the  toplevel loop, the VI will run out of code and stop naturally.
  • There is a lot of duplicate code. Many cases are almost identical and could share most of their code if arranged right.
  • Your toplevel loop spins as fast as the computer allows. It needs a small wait.
  • Your random number generation is not fair because 1 occurs at twice the probability of 0 or 2. Think about how to fix that.
  • Your subVIs use up to 9 instances to index the same array. One is enough! you can resize it to 9 outputs.
My suggestion at this point would be to improve your current 3x3 version until the code is significantly cleaner. It can probably be done with 20% of the current code. You need to learn the basics without the additional complications of a larger board.
See how far you get and post your improvements. We will tell you once you are ready to go to 4x4.
Message 5 of 9
(3,986 Views)
Thank you for your advice
Message 6 of 9
(3,972 Views)
Do you really only have LabVIEW 2010?
(I made a quick and simple draft to give you some ideas, but I don't really want to down-convert it that far....)
Message 7 of 9
(3,927 Views)
@altenbach wrote:
(I made a quick and simple draft to give you some ideas, ...)
See also this gem. 😄
Message 8 of 9
(3,878 Views)
Thank you for help me.
Message 9 of 9
(3,850 Views)
