 plpablo
			plpablo
			08-15-2018 06:26 AM
Hello all,
I have problem with values on time axis on my Waveform Chart. I would like to start axis form 0s and end automatically at the end of the measurement.
But I have some strange value you can see on the picture
			08-15-2018 06:38 AM
08-15-2018 06:47 AM
Graph will be updated in realtime ?
			08-15-2018 07:01 AM
08-15-2018 11:35 AM
Hi GerdW,
As you suggested I changed chart to Graph.
Now my 10 s measurement looks like picture in the attachment but it should end in the middle of the graph. How to customize time axis ?
 JÞB
			JÞB
			08-15-2018 12:18 PM
Auto scale
08-16-2018 03:38 AM
When I Use auto scale I do not see mesurmet form the beginning.
I need to see graph from 0s to the end on of the plot.
			08-16-2018 03:44 AM - edited 08-16-2018 03:46 AM
Hi pablo,
Then you need to collect the needed data for the graph, similar to the history of a chart.
Did you examine the example VIs coming with LabVIEW in the example finder? There is an example explaining the differences between charts and graphs and how to use both…
08-16-2018 09:01 AM
according to information found here :
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9zsSAC
if I want add dynamic data in the loop I should use chart, but in chart I have problem with time scale.
so question is chow to work with graph in loop or how to get time axis right in the chart
			08-16-2018 09:18 AM
