Time Axis on Waveform Chart porblem
Hello all,
I have problem with values on time axis on my Waveform Chart. I would like to start axis form 0s and end automatically at the end of the measurement.
But I have some strange value you can see on the picture
Message 1 of 21
(4,403 Views)
Hi plpablo,
use a graph to get a good customizable time/x axis…
Charts are limited here!
Message 2 of 21
(4,401 Views)
Graph will be updated in realtime ?
Message 3 of 21
(4,398 Views)
Hi pablo,
the graph will be updated when you wire new data to its terminal…
Message 4 of 21
(4,390 Views)
Hi GerdW,
As you suggested I changed chart to Graph.
Now my 10 s measurement looks like picture in the attachment but it should end in the middle of the graph. How to customize time axis  ?
Message 5 of 21
(4,370 Views)
Auto scale
Message 6 of 21
(4,364 Views)
When I Use auto scale I do not see mesurmet form the beginning.
I need to see graph from 0s to the end on of the plot.
Message 7 of 21
(4,348 Views)
Hi pablo,
Then you need to collect the needed data for the graph, similar to the history of a chart.
Did you examine the example VIs coming with LabVIEW in the example finder? There is an example explaining the differences between charts and graphs and how to use both…
Message 8 of 21
(4,346 Views)
according to information found here :
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9zsSAC
if I want add dynamic data in the loop I should use chart, but in chart I have problem with time scale.
so question is chow to work with graph in loop or how to get time axis right in the chart
Message 9 of 21
(4,333 Views)
Hi pablo,
did you look for example VIs in the examle finder?
Anyway, here's an example:
Don't get used to DDT wires and your life will become easier…
Message 10 of 21
(4,330 Views)
