Time/Date string to seconds?
Thanks Frozen for the "Edit" and credit...
Also thanks for posting a proper screen capture (I don't have LabVIEW installed on my "Internet Computer".)
What I thought was most interesting is the ability to just Use %T and not have to remember all that formatting gobbly gook (%<%Y-%m-%d .....).
Cheers
Certified LabVIEW Developer
LabVIEW 7.1 - Present
Message 11 of 21
(2,635 Views)
Watch out with the %T formatting!!!!!
That will use whatever the current locale is configured for and can vary between computers greatly and even on the same computer between user profiles.
Not a problem if it is just about reading back the file right after it is created but certainly going to bite you if your application is meant to create data files for archiving and read back later from different users.
Rolf Kalbermatter  My Blog
Message 12 of 21
(2,619 Views)
FYI just for fun.
This thread is now the current record-holder in the zombie thread revival thread, a meta-discussion about whether old threads should be locked after a period of inactivity.
(More discussion available if you follow the link, but I'l summarize my own thoughts here:  nope, don't lock 'em.  Searches turn up old threads and some old threads benefit from correction or expansion, like this new record-holder here for instance.)
-Kevin P
Message 13 of 21
(2,603 Views)
Ooooo, I like shiny things and helping or creating world records!
Now another thread I commented on that was created in 2012 has to have some kind of record!
It's 54 pages of comments and I get emails almost daily on it...
https://forums.ni.com/t5/Certification/Sample-Exam-Solutions-for-Review/td-p/1824703
       Thanks for that disclaimer on usage of %T, awesome good to know info!!
Message 14 of 21
(2,550 Views)
Heeeeey!
Here's my contribution to keeping this record alive:
I have ISO-8601-Timestamps like 2026-02-04T08:15:53.645748 in my log data and need them to be Labview Timestamps. Using the method suggested by Frozen, unfortunately doesn't work for me (...or anymore?). I tried it with the "T" between Date and Time aswell with it being replaced by whitespace to match Frozens example. Neither works and i get Error 1. Can anybody help? I can't relate the error message to my problem, as i don't see any weird characters in my strings.
I am on Version 2026 Q1 (32-bit) 26.1f0 - thank you very much in advance!
Message 15 of 21
(1,076 Views)
@Roumaenski  ha scritto:
Heeeeey!
Maybe the decimal separator of your OS is the comma?
Paolo
Message 16 of 21
(1,067 Views)
Hey Paolo,
thank you for replying. It is the comma but where in the code do i have to account for that? I don't see any decimal-character at all in the code resp. the format string. Seconds and its fractions / the 6 digits after the decimal point are not separated in the format string as i understand.
Message 17 of 21
(1,057 Views)
Depending on the actual string you are reading, put %.; or %,; at the beginning of your format string. This will force the localization code use or a period or comma respectively for the decimal separator.
Message 18 of 21
(1,044 Views)
Hey crossrulz,
thanks for the input! Would you be so kind to tell me where exactly i have to put "%." in this format-string?
-> %<%Y-%m-%dT%H:%M:%S%6u>T
Sorry for asking, i still struggle to understand how those strings work resp. how to set them. When i tried several positions, i got the error that there are too many specifiers or it simply didn't work. Thank you!
Message 19 of 21
(1,035 Views)
@Roumaenski wrote:
Hey crossrulz,
As he stated, "put %.; or %,; at the beginning of your format string"
Example: %,;%<%Y-%m-%dT%H:%M:%S%6u>T
Message 20 of 21
(1,028 Views)
