Time Delay NIScope not working
Dear NI Community,
I am developing a TestStand sequence where I capture 2 waveform with my scope. I am using a PXIe5110 and NI Scope for that. I have noticed that the Time Delay between the 2 channels couldn't be measured and it leads to an error. Going in InstrumentStudio to visualize the waveforms, I have noticed that regarding the acquisition was going well. Using the cursors, I also obtain the value that I want.
However, when I try to measure it through the measurement window below, nothing appears for the Time Delay.
Is there something in the configuration that I can do with NI Scope to correct that ?
Thanks in advance for your answer !
(1,145 Views)
How exactly are you using the NI Scope driver to capture the signals? did you code anything in one of the supported ADEs (LV, Py, C# etc.,)?
Please share your code and how you measure the time delay.
Santhosh
Soliton Technologies
(1,141 Views)
Dear santo_13,
Thanks for your answer. I am using NI-Scope drivers in generic steps as I am working with a Hardware Abstraction Layer, that's why it is complicated to share the code entirely.
However, by equivalence, I developed quickly a VI reusing NI-Scope the same way I used it in the HAL and in my TestStand sequence. As you can see, I am using the Read Single Measurement to retrieves the Time Delay. In my sequence, this function causes an error. And in InstrumentStudio, I don't see any results as the picture showed it.
Thanks a lot in advance
(1,093 Views)
Accepted by topic author al0909
Try this modification.
I used multi read measurements and used fetch data to read the raw data
(both read measurements start the reading, your example maybe read 2 times 😉 )
I only tested it with a simulated 5922 I already had ...
I think the time delay measurements needs to know the second channel read ...
Greetings from Germany
Henrik
LV since v3.1
(1,066 Views)
Another try : I added a property node to tell the measurements engine what other channel to use and switched back to single measurement. no error on my side..
Henrik
LV since v3.1
(1,063 Views)
