Time Stamp read problem with Spreadsheet String To Array
Hiii,
      David I want same thing as Senpre wants, that reading the data from the file and displaying it on the XY graph, and i have the .xls file with the text format(tab delimited), but it is whoeing some error and not dislaying anything in the Date/Time Record, can you please explain me what should be done for this, i am sending you example xls file here. plssss do it for me, i have tried so many things for this but not successively atleast single.
Thanks in Advance,
Nishant
Message 11 of 60
(2,074 Views)
Hi Nishant
Oops no file with your post.
David
Message 12 of 60
(2,071 Views)
Sorry,
       Actually i was trying to edit the message but it wsn't happened bcoz of our server failure, now i am sending you the excel file and error both. can you pls show the data on graph???
Sorry and Thanks,
Nishant
Message 13 of 60
(2,064 Views)
Nishant
What I did for Senper won't work for you as your date/time formats are completely different.
In your case you can convert like this
Read up on how scan from string works and look at some of the examples that use it. Tell me what labview are using and I will attach the file if you want it.
David
Message Edited by David Crawford on 02-03-2006 03:48 AM
Message 14 of 60
(2,062 Views)
Hiii, David
      Can you please post me the vi?? i am not able to get somethings from this jpg. plssss
Nishant
Message 15 of 60
(2,053 Views)
What version of labview?
Is version 8 OK?
Message 16 of 60
(2,055 Views)
Ya, it will be OK, but 7.1 is more prefferable, if u r posting it on the LV8, just write down with it, else if possible send it on the 7.1 , coz for the 8 i ve to go to another PC.
Nishant
Message 17 of 60
(2,047 Views)
Version in 7.1 attached
Message 18 of 60
(2,047 Views)
Hiii,
       David, this is waht i want man, but why the time is showing 6:45:57 AM instead of 1:15:57? i think the conversion has been dodne in the 4557 seconds, then after how can i calculte it? coz no to time stamp converts it to the 6:45:57 AM.
Nishant
Message 19 of 60
(2,042 Views)
Its a timezone thing
Message 20 of 60
(2,040 Views)
