Time String to Timestamp Conversion Problem
I attempted to convert time string to timestamp but I failed. What is the wrong with it? I need a timestamp to create waveforms.
Egemen
(4,523 Views)
Accepted by topic author newbieeng
Hi newbie,
use ScanFromString:
(4,509 Views)
You need to provide a date as well. Since you are only filling in the time the date is defaulting to all zeros which results in returng in the default time.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(4,505 Views)
Thank you GerdW. It works well. Mark you are right. But in this case the date is not important for me. Thank you all.
Egemen
(4,480 Views)
I'm having trouble getting ms resolution of seconds into the timestamp.
This gives me tenths of seconds. How can I get down to ms?
(I tried "%3u" [error] and "%.3u" [no change] on the format string for Scan from String.)
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(4,450 Views)
Hi Stevem,
%3u did not give error for me. check with the attached vi.
Best Regards,
Gogineni
Kudos are welcome
______________________________________________
Kudos are welcome
(4,434 Views)
You are right Gogineni, when I got the error, I was using %S in the format string for Format Date/Time String function and %3u in the format string for Scan From String.
I found the solution in this thread - use %S%3u in both places.
(4,424 Views)
