sequential files reading problem from a folder in LabVIEW 2012
Respected Sir/Madam,
                                       I have tried to make a program which
can read files sequentially from a folder and add all second column of all
files into a single file (*.csv).
Unfortunately it's reading files like (1,10,100,1000,11...19,..) but i want
the files will be reading in sequential format (1,2,3,4....1000).
For your kind references, here I attached the vi and the sample files
("renamefiles folder"-sample test data, which you have to read
sequentially).
(by using "rename files folder" will easily understand the sequential
reading problem) (if you add zero in front of file name and make those same digit; will give the correct sequential
reading)
Please find the enclosed documents and do needful ASAP.
Thanking you.
Subhasis Mahata
E&ECE, IIT Kharagpur
(4,755 Views)
Accepted by topic author SubhasisMahata
You need to use a alpha logical sort such as this: https://forums.ni.com/t5/Example-Code/Alphabetical-and-Numerically-Logical-String-Array-Sort/ta-p/39... and place it after your list folder vi
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(4,736 Views)
Drat!  I was just about to post the same thing...
I did mine with variant attributes though. Smiley Happy
(4,731 Views)
.aCe.,
When I download that LLB from the DevZone, I get a message saying it is invalid. Can you post what you have?
Lynn
(4,711 Views)
Lynn,
Thats strange, the link still works for me.
Please find attached the requested files.
Hope this works!
(4,707 Views)
Thanks. That one works.
Lynn
(4,701 Views)
Thanks 4 such a currect &  quick reply. Smiley Surprised
(4,684 Views)
