Time dependent current measurement using Keithley 2400
I ma trying to write a LabView program for current vs time at a fixed voltage for Keithley 2400. Can I measure at 1 millisecond or microsecond interval? How to measure current at fixed interval of time?
(563 Views)
LabVIEW is a programming language.
In order to do measurements, you need data acquisition hardware that has LabVIEW drivers. The maximum speed is determined by the hardware.
(561 Views)
Thanks. I am using Keithley 2400.
(537 Views)
Hi Dbrt,
Ok.
Did you read the manual of your device? Or it's specsheet?
That's the place where you will find answers for your question(s)!
Spoiler
AFAIK the Keithley2400 allows measurements in the millisecond range (when configured accordingly). Microsecond range isn't supported (again AFAIK). Please read the manual to verify what I have in mind…
(508 Views)
