vi not run when i was create exe
hi
what is my problem is when i try open the vi in LabVIEW before build the exe it will work normal as my programming but after converter to exe mean its not open i will attachment my project. kindly any tell me what i am done worng or rewrite or take my desktop remote
(824 Views)
Something like this should work for you, I guess:
(813 Views)
give me all vi files
(807 Views)
Accepted by topic author rajapalani
You're welcome:
(802 Views)
Ya, now its working thank you Could you explain how it works or the fundamentals of LabVIEW to me?
(748 Views)
Yes, its happened, because the path to VI is different in Run-Time (where an application treats as llb), and in in Development.
There are different ways how to get the path or load VI into memory, for comparison refer to LabVIEW - File Path Constants - Development vs. Run-Time Environment example.
(723 Views)
