Time display on multi-plot, stacked chart?
Greetings!
I need to display the time on my chart to the proper current system time on the X-axis.  I've tried different settings in the properties to no avail.  Also, can someone please assist in telling me why I'm getting a "blip" in my chart data every x-amount of seconds (see front panel image).  I'm running the VI with hardware connected.  Adjusting my samples to read or rate in the task does not remedy the problem, so I know it's not that.
Thank you,
D
(3,057 Views)
OK, it appears I have to set the samples to read pro-grammatically, as it appears to ignore the samples to read in Max.  So that fixes one problem.  Still trying to fix the original problem of this post - the date/time on the x-scale.
(3,043 Views)
Try using the build waveform bundle. If this doesn't work, then try using an XY graph.
(3,007 Views)
