Time for another game of "Fix My Rube"
When I went to impliment this, I realized because the delimiters are actually telling me something about the following data, I need to know which delimiter was at the beginning of each match. Is there any easy way to get this? There doesn't seem to be (i.e. it's not an output of the function).
Message 11 of 19
(1,316 Views)
Use my VI, but wire the array of delimiters to the "operators" input instead (leave delimiters unwired), and also autoindex the "token Index" output.
You'll get two arrays, one with small strings and one with indices. Whenever the index is -1, you get the elements of the original solution. If the index is 0 or larger, it points to the element in the delimiter array.
(but wait a few minutes, maybe somebody will post a regex solution :D)
Message 12 of 19
(1,312 Views)
I guess we'll see! Thanks though, works great.
Message 13 of 19
(1,296 Views)
Simply change the replace string to:
\n$1\t
Change the output to a 2D array and the first column is your token and the second is the string.
Message 14 of 19
(1,288 Views)
Darin, you're slacking.  That was more than just a few minutes...
GCentral
Message 15 of 19
(1,284 Views)
\n$1\t
Oh regex's...
Message 16 of 19
(1,284 Views)
He must actually be working today Smiley Tongue
Message 17 of 19
(1,283 Views)
Darin, I'm sure you've seen this already and probably already have the shirt but I couldn't resist posting it as you appear to be the foremost expert on regex in LabVIEW.
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
Message 18 of 19
(1,191 Views)
I like the shirt. My kids would give me lots of grief if I got it though. Smiley Very Happy
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 19 of 19
(1,170 Views)
