Time jumps when I use NI 9217 and the daq assistant
in my program I want to measure temperature and pressure,
the pressure part have no problem and I get the right signal in the right time but if I start the temp. Measurement I get time jumps in my graph and I have no idea why this happen.
I have tried every setting from the daq ass. for the measurement of the temp. (sample, rate, timeout) but it makes not really a difference.
Pleas help me before I freak out.
Best and regards
sascha
Message 1 of 17
(3,523 Views)
Why you have used 2 seprate case structure for temprature measurement, the case selector is same??????
what do you mean by time jump you have programmed it that you will get temp only when you select ????
Message 2 of 17
(3,517 Views)
yes
but i tried who makes the time jumps so i use two case structures,
i mean with time jumpes if i select temp the program runs not fluently the time jumps are up to 2sec.
Message 3 of 17
(3,514 Views)
put timeout value to sample rate / no of samples, so that all the samples could be read before timeout.
Message 4 of 17
(3,504 Views)
thank you for your reply
i do but nothing change the program doesn´t run fluently i tried every combination
if i select only the pressure line the program run fluently
Message 5 of 17
(3,496 Views)
ok the problem part is your ' time has elapsed vi '. you can clearly see the difference if you remove this vi from your code.
you can take a example from the attached vi remove the case structure and see the difference.
may be helpful.............if you try to learnSmiley Happy
Message 6 of 17
(3,490 Views)
ok the problem is your " time has elapsed " vi . Try the attached vi . remove the case structure and you can see the difference . it will give you an idea ............Smiley Happy
Message 7 of 17
(3,488 Views)
Just one comment, you can NOT have two DAQ assistance using the same hardware in the same program at the same time. They will conflict. Combind them together or only run one at a time.
Message 8 of 17
(3,483 Views)
@alok.p
i can not open the attachment i use v 9.0.1
@dkfire
i DO NOT use the same hardware
for pressure i use NI 9215 for temp NI 9217
Message 9 of 17
(3,475 Views)
here in v 9.
Message 10 of 17
(3,470 Views)
