Time measurement for finite varying pulses
Hello ,
I Need help in time measurement .
Attached is the question ,
As in  microcontroller we can use timer to count between N pulses of varying period. say N Pulses 1 pulse 10ms , 2 pulse 20 ms and 3 pulse 30ms duration .
The same way i want to measure time between pulses as marked in Picture , please give  me some solution , I tried using no of samples/sampling rate  it doesn't work .
Pulses i am acquiring is of varying duration .
Regards
Nitin
(3,147 Views)
Accepted by topic author Nitin_110051
Hi Nitin,
what has changed from your other thread to make you think you need to create a double post in a new thread?
Why not stick with your old thread?
(3,143 Views)
Hi Gerd
I lost that link and tried to search but no remembred exact title , so created new thread .
Regards
Nitin
(3,128 Views)
Hi Nitin,
ever tried to click the link embedded in your user name? It sends you to your profil page.
And guess what: there you will find all your threads and messages you ever made in this forum…
Doh! 😄
(3,124 Views)
ohhh goshh,
I will delete this new thread and meet you there at old thread.
Regards
Nitin
(3,105 Views)
