I am working with Windows XP, Labview 8 and the USB-8451 I2C to USB interface-box.
We intend to incorporate the USB-8451 into our product evaluation kits for a new sensor product.
This evaluation kits should be used by our customers when they start working with our sensor products.
The I2C-device is a digital sensor which generates a hold-master condition with difference length, depending on the sensor configuration.
The hold-master is produced by the sensor after full transmassion of start-bit, address, read-bit and ACK.
After the hold master is suspended three bytes can be read by the master.
If the hold-master is kept by the sensor for 25 ms or less I have no problems. When keeping it significantly longer the interface seems not to work properly anymore. I don't get a LabView Error-Message but the PC (Windows?) creates a 'ding-dong' sound very similar to disconnecting and connection a USB device. (the 8451???). My LabView-Program does not show sensor data after this.
I can imagine that the hold-master is somehow too long for one element in the system.
Is there any time-out period for hold-master defined for the USB-8451?
How can I change it to higher values?
Thank you very much for your support!
Message Edited by UnexpectedLifeForm on 02-19-2007 09:48 AM
