Time stamp indicator not appear the fraction of seconds precision
I'm trying to make VI that takes the date and time as an input and create a time stamp. However, the final indicator for time stamp not appear the the fraction of seconds precision.
Kindly, download the attached file for more illustration.
Best Regards 🙂
Message 1 of 8
(2,311 Views)
Accepted by Omda2022
Hi Omda,
this is your current display format setting for the timestamp:
What result do you expect for that display format?
See this simplification:
Message 2 of 8
(2,307 Views)
OK Mr. Gerdw, I understand that the setting format will display the time as HH:MM:SS format.
Any suggestions to get the time stamp in hh:mm:ss.fff  format using another method.
Message 3 of 8
(2,296 Views)
GerdW already gave you a solution.
In your code you are mistakenly setting "fractional second". This value must be less than 1, not a large integer like in your vi.
Paolo
Message 4 of 8
(2,275 Views)
Either that GPS String Time is using a wrong regular expression or i'm missing something.
The regular expression that works for me is %02d%02d%f, the regular expression GerdW provided won't let me run the code due to too many arguments.
Message 5 of 8
(2,266 Views)
Hi AeroSoul,
I just included "%.;" before the "%f" to avoid problems due to different regional settings (aka point vs. comma decimal separator). That "%.;" is a common format code…
Message 6 of 8
(2,257 Views)
Great Thanks Mr. Gerdw for your continuous support. You are helpful and generous person.
How you are strong and professional with NI community.
Thanks alot for all of you
Message 7 of 8
(2,225 Views)
Certainly, Mr. Gerdw give the best solution for the problem. There is another solution here:
 Best Regards 🙂
Message 8 of 8
(2,181 Views)
