Time stamp problem
Hi!
I have a waveform chart, and  I use an "Elapsed Time" block that is converted to time stamp to control the time of the chart.
After the .vi had been running for 01:28:43, the timer suddenly changed to 13178:28:44. The hours are somehow changed to 13178. Is this a known bug, or might it be a programming error of some sort?
It was running as an .exe file, so I could not probe for errors.
Thanks for the help
___________________________________
Is my avatar the dog from the fraggle rock?
(2,560 Views)
I don't think the "elapsed time" is in fault here, I've used it in many application and never had problems with it... How do did you set the X scale format string?
Can you show bits of your code so it's easier to find out what your problem is?
Trying to help
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,549 Views)
