Time stamp to excel .....some thing is wrong in my program
Hi
i am trying to write date and time to excel sheet i got this example from https://decibel.ni.com/content/docs/DOC-2108. but when i tried to write it on excel it is just showing the numbers but not exact date and time what i want.
some body have idea whats wrong in my VI(see attached file)?
thanks
Message 1 of 15
(3,350 Views)
Qazi,
There is nothing wrong with your VI.
After you use your VI and copy this to an excel cell, you have to format it to date/time.
Right click the cell, select Format Cells, and select Date or Time.
Regards
Prashanth N
Message 2 of 15
(3,340 Views)
Thanks for the reply. but is it possible that i could set the format from labview rather then going to excel every time
and changing the format every time when report generated?
qazi..
Message 3 of 15
(3,337 Views)
Hi Qazi,
I wrote a VI for you to make things simpler. It opens an excel file and sets the format of the active cell to date/time. Does this help?
Prashanth N
Message 4 of 15
(3,328 Views)
You might want to swap up to this Version.  There are a few things that LVtime2Exceltime.vi  does not handle correctly (like Zone, DST and the Leapyear Bug in excel)  you may want to vote for this Idea
Message 5 of 15
(3,321 Views)
Hi thanks for the replies but when i tried 'Set_Cell_format.vi* it hangs labview all the time. is there any other solution?
i tried  Time to XL.vi as well but it seems not working not time display at all?
any other idea?
Message 6 of 15
(3,299 Views)
That's odd. I ran the VI before I sent it to you. Which LabVIEW are you using?
Prashanth N
Message 7 of 15
(3,297 Views)
its LABVIEW 2010
Message 8 of 15
(3,294 Views)
I will check it on 2010 and get back to you.
Prashanth N
Message 9 of 15
(3,291 Views)
thanks in addition i have win 7 64 bit
Message 10 of 15
(3,289 Views)
