Time stamp to excel .....some thing is wrong in my program
I tested the VI on a win 7 (32 bit) with LV 2010 SP1.
The VI works perfectly fine. Except of course when the path of destination file is invalid (in which case, it throws an error)
I could not reproduce a hang. Could you try it again. And see which node is causing a hang (or if it hangs right at the start of the VI run)?
Prashanth N
Message 11 of 15
(502 Views)
Actually it runs now but giving me ####### on Excel. and it hangs when i tried to stop the VI.
Message 12 of 15
(501 Views)
Ah, that's expected. You just need to resize your cell long enough to see the date/time.
Doesn't the VI run completely and end by itself?
Prashanth N
Message 13 of 15
(496 Views)
OK now i found that if i run it continuasly then it hangs but run once is fine. i tried to resize the cell after
running the program and i go "26-15-yy hh:15:02 AM" this. but still not showing the proper format i mean "2011-09-26  11:15:02"?
Message 14 of 15
(492 Views)
I think the hang must have something to do with your RAM, because I do not see this program being very memory intensive.
About the format, you can just change it in the constant in the block diagram.
Replace the string constant contents with this:
 yyyy-mm-dd hh:mm:ss AM/PM
Hope I helped!
Prashanth N
Message 15 of 15
(490 Views)
