Timed Loop Incorrect Behavior
Hi Alex,
I see this:
@alexderjuengere wrote:
in labview praxis, I run into a limit at 9.007.199.227.927.314 < 2^53, delta: 26.813.678
And this:
(Both in LV2016 32bit)
Message 11 of 18
(1,867 Views)
Thank you very much for your tests. The behavior you are observing is the expected one.
As mentioned, without any modifications to the executables (the most recent ones being built with LabVIEW 2021), the issue appeared on the same day across several of our production lines as well as on our development machines.
This leads us to suspect a potential link with a probable operating system (W10 Entreprise) update.
Message 12 of 18
(1,842 Views)
This leads us to suspect a potential link with a recent operating system update.
for curiosity, I tested  on a surface pro 8 with windows 11 professional (25H2 build 26200.8246 via winver32.exe)
licence perpetual 1-year subscription
IDE labview 2020 64 bit labview 2026 q1
JB demo.vi alexderjuengere_0-1777904867997.png alexderjuengere_1-1777905063152.png
good luck with re-solving this nasty issue!
Message 13 of 18
(1,825 Views)
@raphschru wrote:
Timed Loops might not be the best choice for non-RT targets.
From what I understand back when they were first released everyone said that Timed Loops were only appropriate to use on FPGA targets. Something to do with the timing jitter inherent in Windows
=== Engineer Ambiguously ===
Message 14 of 18
(1,744 Views)
There is nothing fundamentally wrong with using Timed Loops on Windows, as long as we clearly understand that the loop body itself is single‑threaded (means its content executes on only one thread at a time). As far as I can guess, LabVIEW will generate a single chunk of LLVM code for the loop body, so it still executes on one thread. We can also assign a dedicated CPU core to that loop, which I do time to time, and it works and can be really useful when I need to set affinity to the piece of code.
I only ran into problems once, many years ago with LabVIEW 2010, when occasionally RS‑232 communication happened to be inside such a loop. In that case the execution was sporadically frozen, but that was clearly a LabVIEW Run‑Time issue, not a problem with Timed Loops themselves.
It should also be understood that there is no “magic” involved: using a Timed Loop does not increase the underlying Windows timers resolution. The loop cannot achieve timing precision beyond what the OS (and Windows is not Real-Time by default) and hardware actually provide.
Message 15 of 18
(1,714 Views)
yes! besides changing the OS or making changes to OS (eg. disable real time protection) - busy waiting is making your timers more robust, to a certain extend
https://forums.ni.com/t5/LabVIEW/Which-is-better-between-Wait-ms-and-wait-until-next-ms-multiple/m-p...
Message 16 of 18
(1,676 Views)
Real-Time works with TImed loops also.
Two days late for a Star Wars quote, but: "There is another"
Message 17 of 18
(1,667 Views)
Well it is "Revenge of the Sixth"! 😉
Qestit Systems
Certified-LabVIEW-Developer
Message 18 of 18
(1,643 Views)
