01-27-2022 06:20 PM
Hi All.
I have a time loop (50 mSecs requested duration). I get a poor response for that request.
The white is the loop duration. The green is my computation of execution. The red is "Iteration Duration" from Timed Loop structure. This is close to my execution time.
The LV is 2015 on Win 10.
The Timed Loop setup is;
There does not seem to be any good reason why 50 mSec is not achieved.
Any suggestions?
Regards JC.....
Solved! Go to Solution.
01-27-2022 06:28 PM
@pushkin wrote:
Hi All.
Any suggestions?
Regards JC.....
There are lots of good reasons why the timing isn't what you expect it to be, but I'm not at all sure what the problem is. Is it too slow? Is it erratic? You won't be able to get closer than a couple of milliseconds +/- with Windows.
01-27-2022 07:23 PM
Hi and thank you.
I did find myself at fault. I was computing the period between successive execution endings. So the jitter of execution is reflected in the period. You can see this from the ups and downs. A better graph is below. Period is between successive starts of execution.
My next is issue why does the execution vary so much. Another item. 🙂
Regards JC......
01-27-2022 08:39 PM
Windows is a non-deterministic OS. If you need your loop to iterate at a consistent rate, then you need to move to a Real Time OS, such as NI's Linux RT.
01-27-2022 11:02 PM
Honestly I always thought Timed Loops were for intended for RT targets.
Usually the answers to the posts asking why their program built around a Timed Loop does not do what they think it should reinforces that.
01-28-2022 12:23 AM
I think that is exactly what it was intended for. However, I guess they left it in the general palette because it does help if you need things inside the loop to execute in the same order every time.
01-28-2022 02:28 AM - edited 01-28-2022 02:34 AM
The reason it exists under Windows is because you need to be able to edit a VI intended for a real-time target on your Windows system. If it would not exist under Windows, LabVIEW would not be able to draw the structure and let you configure its specifics. LabVIEW does provide an emulation of the underlying mechanics under Windows in order to let you run your program for debugging reason on the My Computer target, but it is just that, an emulation not the real thing!
Using the Timed Structure for VIs not intended to run on a real-time target is NOT providing any real advantages over using a normal while loop. Definitely not in terms of providing a more real-time specific execution of your code! There is actually a very good chance that it may provide a worse experience in terms of performance under Windows than the normal while loop, since the compiler is very much tuned to perform optimizations on those normal loop structures but can't do it in the same way for the Timed loop structure. Instead the Timed Loop structure interacts more directly with the underlying OS on real-time systems, where its purpose is to provide a more real-time specific execution rather than the fastest possible execution. These two things are very much NOT the same!
