Timeout for IMAQdx drivers
While Grabbing the picture, there is a timeout for IMAQdx drivers so if we stay idle for >timeout and trigger the Grab event camera reinitializes again.
Has anyone faced same issue and how to resolve this.
Any open source tools available to capture abd compare images
(2,259 Views)
HI Uttara,
Make sure your camera is connected properly and it is communicating. Did you check the acquisition in MAX?
Time out will occur after you trigger the acquire event and if camera did not respond.
All the best
---------------- Be Good. Do Good. ---------------------
(2,255 Views)
