When double to digital indicator set to display in time format... Value changes.
Dear all,
I am having trouble displaying the value I want. I have a double value say 320 sent to a digital indicator where I have edited the properites of it to display in a time format containing only minutes and seconds like so, '3:20'. Unfortunately it'll take the value and change it to a another value and display that. I do not know what the issue is. If anyone knows the solution... PLEASE post! 🙂
There is an image attatched!
Thanks.
(2,741 Views)
Surely you don't expect 320 seconds to be displayed as 3 hours and 20 seconds.
(2,739 Views)
Accepted by topic author mechaman
I only believe so due to the fact that when I convert a value from time stamp to double such as 3:20 it gave me 320. So I thought that the reverse might be try. Should I just input the total amount of seconds and that will output the Minutes:Seconds that I want?
Thanks for quick reply.
(2,730 Views)
BTW the calculation done in the picture converts the total amount of seconds to a 3 digit number... the first one being the number of minutes and the last two digits being the seconds.
(2,729 Views)
An actual timestamp data type to dbl does not convert the way you said. Perhaps you converted a string? It sounds like what you really want to do is convert your minutes and seconds values to a string.
(2,722 Views)
