Timeout when consuming a SOAP web service
I'm quite new to Labview and I'm trying to consume a SOAP web service created using a very simple WCF example, but I keep on getting a WebException because of a timeout.
The web service has been created using the example from the WCF getting started tutotial (to keep things simple) http://msdn.microsoft.com/en-us/library/ms734712.aspx
You'll find my .Net solution attached to this message. (You'll have to be administrator to run the service though).
I have used the import web service tool in Labview to create the VI to connect to the web service and all went fine, it created the VI correctly. You'll find the created VI also attached to this message.
Then, I'm trying to create a very simple VI to call the webservice and put the return value inside a numeric indicator. Unfortunately, when I run this VI it crashes with a WebException because of a timeout.
If I run the .Net client, everything goes fine, and if I go to the web service address with a browser, I get the service website, so I know that the server is registered correctly, only Labview can't connect to it for an unknown reason. Everything is setup to connect through localhost:8000, so it can't really be a network problem, I've tried disabling the Windows firewall to see if that was the problem, but it persists.
I've also tried to do something similar using the CDYNE web service, like in the example http://www.ni.com/white-paper/4728/en/, and it works perfectly.
Does anybody have an idea about what could be the issue?
Regards.
(4,449 Views)
OK, I found the problem myself, it was a problem with the configuration of the WCF service, I was missing the ServiceMetadata endpoint.
For reference, if somebody stumbles upon the same issue as I had, here's a service configuration that works with Labview (using .Net >=4.0)
  <system.serviceModel>
    <behaviors>
      <serviceBehaviors>
        <behavior name="">
          <serviceMetadata httpGetEnabled="true" />
          <serviceDebug includeExceptionDetailInFaults="true" />
        </behavior>
      </serviceBehaviors>
    </behaviors>
    <protocolMapping>
      <add scheme="http" binding="basicHttpBinding" />
    </protocolMapping>
  </system.serviceModel>
And here's how to create and run the service host.
using (ServiceHost selfHost = new ServiceHost(typeof(Calculator), new Uri("http://localhost:8000/Calculator")))
                try
                    selfHost.Open();
                    Console.ReadLine();
                    selfHost.Close();
                catch (CommunicationException e)
                    selfHost.Abort();
                    throw;
(4,431 Views)
