Timer in a while loop
Dear experts,
I would like to stop the while loop and save the data after 5 sec. How do I connect a timer switch to "loop condition" (red dot in while loop) so that VI will stop after 5 sec of recording?
Thank you.
CYTeoh
(5,160 Views)
Accepted by CYTeoh
You can't. What made you think you could do something like that? Use the Elapsed Timer VI to tell you how much time has elapsed. You can reset it for the next trigger.
(5,158 Views)
Dear
My application is need to turn off the VI automatically after 5 sec in a while loop. Could you suggest a way to do this?
Your help is much appreciated.
Thank you so much.
CYTeoh
(5,152 Views)
Pay attention. You were told you can use the Elapsed Time function. Look at it. Make sure Context Help is turned on.
(5,150 Views)
Dear
CYTeoh
(5,141 Views)
Your understanding is completely wrong. You certainly did not turn on context help like I said or if you did, you did not read the help details. Nor did you pay any attention to the various outputs of the function. There is a Boolean output. Look at it! Then think about all of those dedicated people at NI that spent so much time writing the help file. Then think about all of those people that post questions who think that's easier than finding the answer themselves.
(5,135 Views)
ok. I got it.
Thanks to
(5,130 Views)
