Timestamp not showing up properly in waveform graph.
I have started using labview only couple of weeks before so forgive me if my question is stupid.
I am plotting a waveform graph from a quantity measured in real time. I take samples every three seconds and append them to array in a while loop using a shift register. On each iteration of the loop I pass this array to my waveform graph. Everything works great.
Now, I changed the X-axis to display absolute date and time. I set the offset value and multiplier at the start of VI and then plot a sample every 3 seconds. I want to show minor ticks on the X-axis, but they are not showing up. I have minor ticks and values enabled in the X-axis properties.
What am I missing?
Message 1 of 11
(4,473 Views)
Hi zomboy,
welcome to the forum!
Well, you miss to attach your VI…
Message 2 of 11
(4,470 Views)
Well, it's very big and messy. But this is what I am doing basically.
Message 3 of 11
(4,452 Views)
Does the VI you attached show the same behavior? I don't see anything "suspicious" and all major ticks have their text. Minor ticks have no text.
Norbert
Norbert
Expert: Geometry
Message 4 of 11
(4,447 Views)
Message 5 of 11
(4,437 Views)
Hi zomboy,
I can also state as Norbert did: everything is nice at it should be…
On your VI: instead of using the value property of the graph you should initialize the shift register! And you should set XAxis.Factor too…
Message 6 of 11
(4,431 Views)
I am on LabVIEW 2009 v9.0 if that has something to do with it.
Message 7 of 11
(4,426 Views)
Accepted by zomboy_
Hi zomboy,
your LabVIEW version could be related to this issue. With LV2014 everything is nice…
Try something like this:
Don't forget to switch OFF "ignore timestamps…" in the axis properties!
Message 8 of 11
(4,420 Views)
Your screenshot shows a different graph than the VI you posted contains:
a) Scale configuration (autoscaling, scale setting)
b) Position of the graph itself
But if i change a) in the VI to match your screenshot, i still see the text next to the major ticks.
Do you execute the VI from within a project?
Also please note that i'm using LV 2014 while you are using 2009. Can you double check with a more up-to-date version of LV if you can reproduce the issue there?
Norbert
Norbert
Expert: Geometry
Message 9 of 11
(4,418 Views)
Thank you for your prompt replies. This seems like a version issue to me. I ran the same thing on LabVIEW 14 and everything works great. I guess I need to figure out something else.
Message 10 of 11
(4,407 Views)
