Timestamping DAQ Data from Multiple channels for logging to an excel file
I am writing a labview application to be installed on a PC as an executable file with the Labview Engine.  I want to acquisition multiple channels from my DAQmx device at different times during my program.  I need to timestamp these data acquisitions and log them to excel to be built as a timeline chart in excel.  I will acquire cahnnel 1 during one phase of the acquisition, and then channel 1 again at the next phase of testing with the hopes of reconstructing these acquisition logs in my excel file on a single chart showing all acquisitions.
How do I create a timestamp system that can log this data with precision?  The DAQmx VIs only bring data back in a double array or a waveform.
(3,060 Views)
A waveform consists of a timestamp for the first data point of the array, a very precise timestamp, and also a dT, the time interval between data points.  You can do the math to figure out the precise timestamp for each point in the array.
(3,048 Views)
Just use the Export Waveforms To Spreadsheet File function.  It accepts your waveforms and writes to a text file which Excel can read.  It even does the timestamp for you.
(3,017 Views)
