Timing is off
I am certain there is a simple solution but I haven't written a VI in several years. Attached is a snippet of code that calls on a sensor connected via 485. I am struggling to control the frequency of measurement. I would like to be able to tell it to read data 10 ms, 100 ms, or 1000 ms, etc. but at the moment I can't seem to control it. Any thoughts?
Thank you.
(4,002 Views)
Accepted by Geologian
It looks like you are reading from 2 separate channels? The "Wait (ms)" you are using has the effect
Start For Loop
Wait X ms
Read Channel 1
Wait X ms
Read Channel 2
Exit For Loop
(3,999 Views)
Can you dumb that down for me? I don't know how to break the 2 channels into separate reads as you describe. Thanks.
(3,986 Views)
I think you already are doing 2 reads by using the For loop
(3,977 Views)
I was totally overthinking this. Thanks.
(3,926 Views)
