Title in the "Write to Measurement File"
here I upload my file so that you can understand what i mean.
And I test just the voltage , without the current and power
file named '1' is the block with the "Set dynamic attribute" with set the first column "time" , after that you can see that everything is in its column ,but there is no time intervals in the first one
file named '2' is without the "set dynamic attribute " to modify first Untitled into time , so everything is in mess,but I can read out the time intervals
Message 11 of 12
(842 Views)
Hi
I have exactly the same problem, the first column must be the time, but since I use the set dynamic data Attributes the columns is always "0"
I have 10 kinds of data and time, but the set dynamic data only let me choose between 0 and 9. If I choose the index 0 fora time, the time appears, but I lost the last kind of data.
Best regards
Carlos Palha
Message 12 of 12
(683 Views)
