To Reduce execution time of a loop
The most common reason I have seen for "slow" programs is the dynamically building of arrays.  Build Array and Insert Into Array cause memory reallocations, which is a slow process, especially when the arrays get large.  Try to initialize the arrays to the needed size and use Replace Array Subset to build up arrays.
GCentral
Message 11 of 11
(602 Views)
