To delete a non repeated element from Array.
Check this
Message 11 of 18
(3,057 Views)
Actually I need the non repeated elements to be deleted and the repeated elements to be printed once.
Message 12 of 18
(3,014 Views)
Hi Hemanth,
I'm sorry, I implemented it in the opposite direction…
Adapt as needed - or use the Map approach also shown in this thread!
Message 13 of 18
(3,007 Views)
Here are a couple different ways.
Message 14 of 18
(2,994 Views)
Can u help me out i can't figure it out....
Message 15 of 18
(2,968 Views)
Hi Hemanth,
Who is "u" and why can't you use one of the suggested solutions?
Message 16 of 18
(2,958 Views)
Accepted by stark8
Have you tried my solution?
Is your expected output matches with the below results
Message 17 of 18
(2,947 Views)
Accepted by stark8
I would probably use a map as follows (Note that the input does not need to be sorted):
Message 18 of 18
(2,929 Views)
