To make a control that can be initilaized during runtime
In case of an enum or a ring constatnt. The options to be selected need to be listed during programming
Can the option to be selected be done during run time.
I have an array, and i can route the 1st column to be the values in the drop down menu, need to select any one during runtime.
Please help.
Regards
Grugh Mike
Success is Everything !!
(2,843 Views)
Enums can't be defined at runtime, but Ring controls can.
Write to the Strings and Values property node to populate the ring control.  To set it to a specific entry, then write to the Value property node.
(2,841 Views)
Thank you for your reply.
I am attaching a zip file which has a sample program which i made.
Here the only thing i need is that, i want each element in the array to be selected by a drop down menu.
I tried combo box as in attached file, but that didt work.
During the file excution the "pass folder is to be pased in the C drive"
Regards
Grugh Mike
(2,828 Views)
Accepted by Grugh_Mike
Hi Grugh Mike,
I am not sure how to do it with an array of combo boxes but if the number of rows in your file is limited then you can try the attached example.
Nitzz
(Give kudos to good Answers and Mark it as a solution if your problem is Solved;))
(2,825 Views)
Thank You very much for the reply.
Regards
Grugh Mike
(2,805 Views)
