Showing results forĀ
Search instead forĀ
Did you mean:Ā
To save data into an array according 2 labels
I need to save the Data into an ARRAY.
And I need to save it according 2 labels: GROUP name and ELEMENT name.
Suppose that I have following:
1. Several GROUPS of Data like this:
    ER-1234
    ER-3245
    ER-4786
    ER-9080
2. Each GROUP has the following ELEMENTS:
    A, Bi, Pb, Sn, Sn, Cr, Ni, Ca, ...., Al
   So it would be like
    ER-1234: A, Bi, Pb, Sn, Sn, Cr, Ni, Ca, ...., Al
    ER-3245: A, Bi, Pb, Sn, Sn, Cr, Ni, Ca, ...., Al
    ER-4786: A, Bi, Pb, Sn, Sn, Cr, Ni, Ca, ...., Al
    ER-9080: A, Bi, Pb, Sn, Sn, Cr, Ni, Ca, ...., Al
 3. An each ELEMENT has DATA that I need to save, BUT! that I need to be able to get it by specifying the group and the element.
    A:
         2,3   2,4    2, 8,   2,8
         2,2   2,3    2, 7,   2,6
         2,1   2,6    2, 6,   2,7
         2,5   2,4    2, 5,   2,3
How can I save the ELEMENT "A" Data with the label of the GROUP and the ELEMENT into an array?
I will need to be able to get the DATA again when specifying the Group and the Element.
Thanks for the help!
Amaloa.
(3,619 Views)
If I understood correctly, you just want a 2D array for storing your data and two index for the row and column. See the attached example.
Software developer
www.mcm-electronics.com
PORTUGAL
(3,609 Views)
Have you looked into making your group and elements into Type-Def. enums. If you do that then you can use an enum with the Group and Element name to index a 2d array.
For example, the Group would be an Enum like:
0       ER-1234
1       ER-3245
2       ER-4786
3       ER-9080
and the Elements
0      A
1      Bi, etc
Then to index Group ER-3245, Element A would be index row 1, column 0.
And if you need to save an array as the data, you can make a cluster of numbers, then make an array of clusters.
(3,608 Views)
Thanks for the reply.
Could you please show me how to do and use an "Type-Def. enums"?
I tried to find an example, But! I did not succeed.
Note: The solution to my problem would be to use the Type-Def enums as you wrote before.
Thanks again for the help!!!
As.
(3,564 Views)
Jorge, thanks for your feedback. The .vi you sent helped.
Steven, I will wait for your feedback.
Thanks!
As.
(3,562 Views)
A type-def. is just a custom control. From most LabView windows select File > New >  Then select custom custom control, under Other Files (in 8.5) Put an Enum on the Front panel, edit the entries to what you want, make sure "Type-Def" is selected from the drop down menu on the toolbar and save the file as a .ctl. You can then place the custom Enum as a control, constant or display in other VI's by selecting "Select a VI" or "Select a Control" from the functions palette, then navigating to your custom control.
Hope this helps.
(3,550 Views)
