06-17-2009 04:05 AM
Hi, I am developing sensors (mass flow controller, thermocouple etc) and uses DAQ to read the data. Then I write the data into TDMS format.
The problem is I need to read the data at 1sec interval but write the data into TDMS format in 10sec interval.
I developed the vi in a while loop which I set the timing to be 5s while I figure the sampling rate of the DAQ Assistant to 1sec. But both read and write have the speed of 5s.
Please kindly share your opinion.
Thanks and regards.
06-17-2009
04:41 AM
- last edited on
07-22-2026
08:24 AM
by
Content Cleaner
Hi!
Is the entire .vi in one loop?
If that is the case a queued producer/consumer architecture would be a solotion you could look into.
06-17-2009 09:26 AM
Thanks Jan. Will read the link you provided.
I tried several method; separate into two while loops and writing of data into TDMS in a while loop inside a while loop with DAQ. Both failed.
06-17-2009 01:24 PM
What do you exactly mean by this? Is it possible for you to post a snapshot of version of your code that isolates the issue?
