daq reading voltage
Hello
I´m using a NI USB-6211 to acquire voltage. I´m using voltage probes with atenuation in order to measure values above the limit of +-10V.
The problem is:
- The value that I read in Labview (RSE, continuous samples... just a straightforward reading) is not sensitive to atenuation
This means that when I´m reading 8V without atenuation (confirmed with voltmeter at the pins of the daq board) I'm reading 8V -> Correct
When I use an atenuation of 10x and reading 0.8V at the pins of the daq board with the voltmeter, I still read 8V in Labview -> Incorrect
Hope that my question is understandable
Thanks in advance
(5,274 Views)
What kind of probes are you using. If you are using scope probes your setting will not work because scop probes are made for 1 Mohm input.
A scope probe look like this
The RP is a 9Mohm resistor. The ratio is equal to Vin*(Rin/(Rp+Rin)=Vin(1/(1+10). Your daq board has a Rin equal to to 10 Gohm. So the ratio will be in Mohm=10000/(10000+1)
Message Edited by Coq rouge on 05-25-2009 03:35 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(5,258 Views)
Sorry made an error in my last equation. The correct ratio are 10000(10000+9)
(5,247 Views)
Accepted by topic author fadetoblack
Hello
Thanks for the help. You are absolutely right!!
I´m going to modify the input circut in order to include the 1Mohm resistor and then pass the voltage value to the daq board.
Thanks again
(5,235 Views)
Greetings
I am using LabVIEW version 7.1 with a National Instruments PCI-6713 12bit.
I am not at all familiar with the LabVIEW program.
Can anybody please provide a (simple) voltage data acquisition software?
It will be used to obtain data from some brand new Kistler pressure sensors for a Research Project.
One or two channel does not matter - if one I will use one pressure sensor at a time.
Grateful for any assistance; ofcourse recognition will be possible in any acknowledgements and/or publications if desired...
(5,163 Views)
As a starter you can go to help in the toolbar and then select find examples. Serach for "continuous acq" I think the example "Cont Acq&Graph Voltage-Int Clk" should be usefull. All examples that show a MX icon is correct for you
(5,155 Views)
Your question has nothing to do with the original post and you should really have started a new thread.
You can find a lot of examples just by going to Help>Find Examples. You will of course, first have to find a different DAQ board since yours is not capable of acquiring a signal. Did you ever look at the specs?
(5,154 Views)
