Toggling program to sort data sets during acquisition
Here are the other two programs.
Unfortunately I cannot submit the typical output because I do not have access to the machine. But, the output is a 2D array with the 0th row as the x-axis and the 1st row as the y-data.
mrphud
Message 11 of 20
(1,251 Views)
Which SRS model are you using DG645?
Message 12 of 20
(1,246 Views)
The 2D Waveform to 1D Array.vi seems to just select the first row of the 2D array.  Index Array would be much easier, if that is what you want it to do.
But it seems more likely that you want the second row (y-axis data) and perhaps the third row when you start acquiring the laser trigger signal.
This is where typical data becomes much more useful than guessing.  Without being able to see the data is it almost impossible to suggest ways of hepling you get what you want.
Lynn
Message 13 of 20
(1,241 Views)
It's a DG535. But, I have two of them, so I am able to generate two repetition rates.
Message 14 of 20
(1,236 Views)
Hi Lynn,
I decided to use index array instead of my sub vi, you are correct it is much easier. As for the data, it is the output of a waveform graph. The standard output of a waveform graph is precisly what you said. 0th row is x values, 1st row is the first set of y values, and the 2nd row is the second set of y values. This should eliminate the guess work.
Can we at least play out this scenario? I tried to use decimate array but it only seems to work with 1D arrays. Is there a way to decimate the 2D array?
mrphud
Message 15 of 20
(1,227 Views)
Yes, the Decimate Array only works with 1D arrays.
If you put Decimate Array inside a for loop, it will decimate each row separately. Depending on what you want to do with the data later you may need to use Index Array to select a particular row or column from the decimated arrays.
Is the laser on data in odd columns and laser off in even columns or is it distributed some other way?
Lynn
Message 16 of 20
(1,220 Views)
Whether the laser on data is in even or odd will (I believe) change from scan to scan. This is because I have no way to set the program to start the scan in the same state every time.
Also, I don't need to decimate my 1D array. I need to spilt the collection of 1D arrays, hence a 2D array, into a group of 1D arrays of the same data type. I suppose I could do this with an extra for loop and index array.
The better way would be to use the second row of the oscilliscope output to check whether the laser is on.
So this is now the question. If I sent a square pulse to the second channel, at irregular intervals, how could I detect whether it was there or not?
Message 17 of 20
(1,216 Views)
I have attached a little VI which shows some of the concepts I have been suggesting.
Splitting the arrays can easily be done with Index Array.  No loops required.  The Index Array function can be expanded to get multiple rows (or columns) simultaneously.
The third row of Array in my VI has a value of 20 for one state of the laser and 25 for the other state.  The second row has data which increases linearly with time except that I added 20 to the value if the laser was on.
Array 5 has the laser off data and Array 6 has the laser on data.  The use of NaN was so that the data do not appear on the plot and so that the arrays could be truncated later for further processing.
Note that Initializing the arrays outside the for loop and using Replace Array Subset inside the loop avoids memory re-allocations and is the preferred way to handle arrays which might become large.
From some of the questions you are asking it seems that you do not have much experience with LabVIEW.  The on-line tutorials are a good place to start.
Lynn
Message 18 of 20
(1,208 Views)
You are correct. I have a decent understanding of programming, but I am new to labview. In any case, I appreciate your help.
mrphud
Message 19 of 20
(1,196 Views)
Accepted by topic author mrphud
As an update I am posting the code that I believe is finished. I was able to use a second "trigger pulse" to tell the program whether the laser was firing or not. That is the min max comparison for the data from channel two. From here I will integrate the averaged subtracted signals. See attached file.
Message 20 of 20
(1,180 Views)
